Hegner Multimax-3 $275
Jim Hancock
For sale is a very lightly used Hegner Multimax-3 scroll saw. It comes with two full blade holders so you can easily swap back and forth between blades, and lots of brand new blades. It also comes with the owners manual, a very good book that has good information about the Multimax-3, and the original box that the saw came in. I replaced the bellows recently. This is the single speed version and I do not have the big factory stand or foot switch that you may see in some other pictures of scroll saws. It is in my shop(climate controlled) so it can be tested out.
Berta
Berta
I have never tried a Hegner. Does it require a tool for blade changes? Is it bottom feed only?
Jim Hancock
It uses v-blocks for the blade, and once the blade has been mounted in the v-blocks it does not require tools for change out. It comes with two sets of v-blocks, pretty sure you could get more if that suited your scrolling needs.
Michael Mathews
Michael
is there a quick release to change the blade? or do you have to de-tension with the knob on the top rear of the saw?
