Have You Tried Propane?
One of the big problems with solvent based finishes is "drying in the can," and forming a skin on top of the finish in the can. There are commercially available products to help prevent this from happening. But ordinary propane, the stuff in your gas grill, has all the necessary properties to do this also. First, it's heavier than air, so it means it will displace the air in the open portion of the can, It's dry, containing no moisture, and it's CHEAP! To use you need a regulator and hose for gas grill. Before closing up can of finish, slowly add propane to the can above the finish, by using open end of hose attached to regulator and cylinder. Place the lid tightly on can, and next time you open can, there won't be a skim on top of finish, ruining it. Last week, I used some Rustolem that I had previously done this too. When I opened the can, there was no skin on top of the paint, as there was no oxygen in the can to start the reaction needed to set up finish. I dont reccomend trying this using your torch, as it mixes propane with air, defeating the whole purpose for doing it. Credit for this idea belongs to Tom King over at Saw Mill Creek.
HITCH-
Hitch
I find this idea somewhat dangerous when there are so many safer solutions to the problem.
You can buy pint sized bags of glass floral beads at the dollar tree for $1.25. Drop in enough to replace the air in the can and you are good to go.
My preference is the stop loss bags that allow you to vacate the air from the storage bag.
AllanD
Allan
That would be a useful option for many since most every household has a gas grill. Luckily I have a few welding machines so it is really convenient to flow some inert gas into the can. The regulators are adjustable so you can crank it open just a little as needed.
An explosive gas, sitting in a can with petroleum distillates - what could go wrong?
Aren't those petroleum distillates explosive? According to warning on labels, they are. Exactly how much propane are you filling can with? Probably less than leaks from grill before it's lit. Remember that propane is mixed in the correct ratio to burn. What do you think thas propellant in "rattle cans" of finish is? It ain't air. Propane has been used as a refridgrent for years in Europe. Many new appliances being currently sold in the US also use propane. Must be safer than some expect. Remember, being heavier than air, it's not going to run out of the can, unless you turn can upside down. Then I don't think the propane will be your biggest worry.
When you finish with can of finish, then what do you do with beads? Discard them as trash, or use a bunch of air and ground polluting solvents to clean them. The amount of propane in a finish can is less than what your wife releases when spraying her hair.
petebucy4638
Pete
Propane is used in the US for refrigeration too, but that is a closed system. Using propane as you describe may be a viable solution. I'll stick with argon or nitrogen.
