I have spray finished some shelving units, and their backs, with a primer and the white the Target EM6500 product. The result is fine when viewed head on (perpendicular) - no issues in coating. However when viewed in low angle bright light, it is clear that my work suffers from gloss level variations. Note that I stated MY work suffers, I doubt this is product issue (although it could be). Spraying with a Spray-it 33000 LVLP gun, setting the flow and fan about a high as I can get in order to provide wide coverage. Product thinned maybe 5% with water.
Hard to capture but the variation with a camera, but here is the best pic I was able to get.
Any ideas on what might be the issue - I don't know if the flatter sheen is the expected level, or the glossier. Variations most clearly seen on the far edge.
I have similar issues where I spot-patched, re-primed, and double coated with the EM6500. These areas have a flatter sheen than the surrounds.
In uses these pieces will never be viewed under that sort of lighting conditions - unless one is a contortionist - so in practical terms this is a 'non-issue'.
If I ever use this product on a piece of furniture that is free-standing, it will need to hold up to scrutiny under a wide variety of lighting conditions; theefore I want to understand how to spray it well...
Thanks
EDIT - Jeff Weiss' answer (Target) is found below in the thread - end EDIT
Edit 2 - further confirmation of Jeff's operator error hypothesis - see bleow
Thanks
