After finding that the outfeed table I bought for my SawStop PCS would not work with the mobile base, I opted to build my own. Due to the placement of the saw in my small shop, I need to move it pretty frequently. In addition, I often need to move around the back side of the saw - so being able to quickly fold it down is important to me. Finally, I've found that sometimes it would be handy to have at least 24" on one side of the blade or the other. Rather than build two tables, I've designed it to slide to where I need it (one really wide table wouldn't work in my shop).
I started by adding some support rails. The top rail was easily bolted to the rear rail of the saw using the existing holes, but the lower rail required drilling into the cabinet.
Here's a closeup of the top rail:
Next, I built a sliding carriage to support the table on the rails:
Next came the hinge mount, which sits on two bolt heads to allow fine-tuning of the height of the table for perfect alignment with the saw top:
Here is a closeup of the adjustment mechanism. Once the table is installed, the height can be adjusted by loosening the screw (in the fender washer) and then raise/lower the bolt to adjust the height.
Next, the table is mounted to the hinges:
Here is the table extended...currently supported by a sawhorse:
My next task is to design some supports that will hold it up when in use. Then I'll need to put miter slots into the table and perhaps add some laminate to the top.
Anyone got any good ideas for the supports? I've considered looking for some hardware, but would want to buy it locally, so I can try it out and return it easily. I'm too far down this road to design the project around the hardware...probably should have thought about that before now I've got a pretty simple locking arm design in mind, but am open to suggestions...
