When I went to pick up the vacuum press in late January I was asked to quote making four examination tables that would match some stock cabinets from Lowes. I finished those back in March. Here is a picture of the finished tables.
Things I learned from this project:
The best way I could find to match the Lowes finish was to buy oops paint and thin it 50/50 with distilled water. I wiped it on, and quickly wiped it back off. I then used spray shellac and three coats of water based poly. I raised the grain before I started and that made a huge difference. Instead of steel wool(which could rust), I used the 0000 nylon pad to smooth between coats.
Upholstery stinks. This was my first upholstery project, and hopefully my last. The materials alone (2" foam, poly wrap, and vinyl were about as expensive as the 8/4 maple).
Even soft maple is really hard. It ruined my freud ripping blade. Luckily the people at Raleigh Saw did a great job sharpening it for me. For the large dadoes, I rough cut them on the band saw to remove most of the material and finished cutting them on the table saw with my dado set.
I love the tapered drill bit countersink sets. I used it for the first time with this project and it did great in the maple.
I didn't want to add leg levelers because the legs were so substantial and I wanted the full cross section touching. Instead after I delivered them and placed them, I used iron on edge banding to fix any wobbles.
Amy
Amy
