I'm getting down to the short rows in my gun cab. I need to make the doors for the front, and the butt rest and a slotted barrel rest.
The doors are no problem.
He wants to be able to put his side-by-side double barrel shotguns in any location, so I will drill 2 inch diameter holes with a forstner bit, 3.5 inches on center across the board and use the BS to cut straight from the edges of the circle to the front of the rest, making a U-shaped slot. The board will be 38 1/2 L x 3 W. I will probably have to cut the straight slot sides for the center slot with a TS and finalize with a hand saw. I have considered gluing in a board under the barrel rest (perpendicular) mostly for looks since there will not be any vertical load. I will add bracket boards at either end for support and looks.
For the butt rest, I wanted to mimic the barrel rest with 2 inch wide slots, 3.5 inches on center and the slot length would be 6 inches overall, with semi-circle ends. I could make two "halves" for the butt rest then edge glue. This would have the butt rest enclosed so the gun butt couldn't slip forward. Good plan, I thought to myself.
I talked with my friend and he had envisioned the barrel rest according to my plans. However, he wants the butt rest to be enclosed, and really wants the shape to be elliptical - "like a biscuit for a biscuit jointer" is how he described the look. I am not sure how to go about making that cut twenty times (ten slots per each gun butt half) and ending up with something that is consistent and symmetrical. Any thoughts on the design and construction in this area would be appreciated.
Chuck
Chuck
