My parents wanted a stereo cabinet to hold their stereo components, XM radio receiver, and CD collection but were unable to find anything that fit the area they wanted it located in nor in the style they liked. I said that I would make it for them if they provided me the specs.
Here's what I got to work from -
Keep in mind my Dad is a fine draftsman, but not a woodworker so disregard some of the notes like stock dimensions and staining the Cherry
At one of the early spring lumber runs I got some sweet, wide Cherry from Ivey, the boards were only 6' long but most were 11½" wide and almost perfectly clear. It's been air-drying in my shop since then.
I cut the boards in half to make them more manageable, and ~39" was longer than any part of the cabinet.
In a stroke of genius I decided to mark the ends of the boards so after ripping them to fit my jointer I could glue them back in their original orientation -
The wide boards were then ripped in half on the bandsaw to prepare them for jointing -
I proceeded to joint one face and then move over to the planer to flatten the other. I just got a nice set of hearing protection for Xmas (probably too late as my wife tells me I'm deaf as a rock) they really are nice there is no ringing in my ears after running the lunchbox planer. The only problem I found is that I can't hear that tell tale sound of my chip separator filling up and over loading the DC.
Argg...the mess -
After cleaning out my DC I resumed my milling operations. The stock now S2S goes back to the jointer to get a true square edge on it. I like to do this after planing so I can chose which way to run the stock over the jointer to avoid any chip-out. After straightening one edge I move over to the TS with a Freud GLR blade and straighten the opposite edge. Then you have a nice stack of S4S boards -
Using my markings I was able to glue up the top and 2 side panels each out of one board each to keep the grain and color consistent -
The glue up didn't seem to be effected by the different color clamps :roll:. The Besseys are definitely the lightest, the Jorgys have the best action. I was really glad to have my new clamp acquisitions to allow this much to be glued at once.
I pulled the panels out of the clamps today and cleaned up the glue and gave them a good 80 grit sanding and here's the results -
And now for the first in many questions as I embark on this project (actually I've already asked a few about it in the pre-planning stages)
I think I know the answer to this one but I would love confirmation and reassurance.
I plan on joining the shelves to the sides and the overhanging top to the sides in stopped dadoes. I shouldn't have any problems with wood movement if all the grain is oriented the same way (ie top and shelves long grain right to left, and sides long grain bottom to top)????
I've saved the remaining stock to do the RP doors and false drawers so the outside of the cab will have good color continuity. I will have to get some more Cherry to build the shelves. It's amazing how fast you can go through 40 BF of lumber in a project.
Hopefully I'll get the dadoes cut next weekend and the shelf stock milled and glued. I am going to wait until the carcass is glued up or dry-fitted and my new Freud door router bit set arrives to start on the doors. They will be my first venture into RP doors and cope/stick door construction...more questions I am sure.
Thanks for making it to the end of my long winded post. Please stay tuned to next Sunday for the next chapter.
Dave
Argg...the mess -
Dave
