I have started a project to make Celtic knot trivets for family members. The first (pictured) was cut from 1/2" Brazilian cherry using a scroll saw. Celtic knots have an over-and-under look. To simply mark or burn the lines still leaves a flat appearance. In trying to duplicate the rounded over-and-under look I variously used a carpenters chisel, a knife, sandpaper, rasps and a Dremel with sanding attachments. Besides being very time consuming, I am not entirely satisfied with the results. A finish-carpenter friend suggested a small wood carver's set might create the desired effect. If so, would I need all 5 plus chisels/gouges, etc that make up sets? It isn't like I am going into wood carving: I just want to improve the detail on some scroll saw and bandsaw projects. Any advice will be appreciated.
