Does anyone have one? If so, do you have the part number to the bearing itself?
Thanks in advance.
Thanks in advance.
Help me to understand this, do you only use carter stabilizer if you're using narrower blades?
That's the way I use it. I have a little 10" Rikon bandsaw and usually use the Carter stabilizer with either a 1/8" or 3/16" blade, though it works fine with a 1/4" blade as well. It holds the back of the blade stationary, but allows the front to flex from side to side a little bit - obviously with a 1/8" blade, it doesn't move much, though. The bottom guides are backed off completely. The bearing is pushed against the back of the blade enough to "load" it with some pressure, and the blade tracking is supposed to be adjusted toward the rear to add a bit more pressure to the bearing.
I love it. It can make incredibly tight cuts that I never thought were possible on a bandsaw with it.
