First, know where the bar is. A nice little 6" grinder is the Baldor 623E. Over the years, Baldor wasn't necessarily the best they are as good as they need to be so these days they are the last man standing. Good grinders are hard to find on the second hand market and most will require new tool rests and other little parts that get damaged during use.
Probably a good starter is one of the inexpensive Asian imports.
A bench grinder is a metal working tool. There'll be a learning curve involved. A pass on the bench grinder will remove maybe .001 at best. Keep the passes light and consistent. Shaping a tool will take many hundred passes. I'll usually make fifty light passes and check the progress. Most people can do fifty passes in less than a minute or two.
A grinder will shape the tool's cutting edge. After the tool is shaped the way you want it, a honing stone will do the final sharpening. Going right from the grinder to the wood won't give anywhere near the cutting smoothness you'll get if you hone (sharpen). Also, going right from the grinder to the wood means you'll wear down an expensive tool in no time. I can usually get five to seven sharpenings before I have to go back to the grinder. I've got tools I've had for two decades that still have plenty of useable steel.
I see a lot of people that get a China-made grinder and then add a Wolverine sharpening system. This a good way to start. Grinders come and go, but the Wolverine systems can easily move from grinder to grinder.
Get something and start practicing. After 40 years of using bench grinders, I've accumulated about 15 grinders and buffers and only a couple were bought new.
My preference is the 3450 rpm grinders because they get rid of the metal quicker. Light quick passes won't heat the tool to make it uncomfortable to hold. With modern high speed steels, if it were your job to remove the temper with a bench grinder, you won't be able to do it.
For hand chisels and the like, again, I prefer the 3450 rpm. Light quick passes won't heat things to ruin the temper. You'll have to do slow hard passes to ruin the temper of regular carbon steels usually found in chisels.
