Ok Jeff, Now you can start the clock on the bedside table project!
1st pic shows the cherry, curly maple and QSO from The hardwood store. $350 just to start with!
After a week in the shop I rough milled it to let it acclimatize to the shop.
After another week I milled the case panels to final dims. Because of the limitations of my 6 inch jointer the case sides which are 13" wide were made from 3 pieces; two of which came from the same board, but re-ripped and grain matched to a 3rd board. I kept the board long enough so that the grain will wrap around the corners of the cases.
After joining the edges using the "book" method to guaranty the joints were good I glued up the panels using the Bow clamp cauls that Dave O lent me - more on those in another review. I had the usual problem of keeping the panels flat under the pressure of the clamps and having the assembly table and being able to clamp down with long cauls really made a good job.
Now the panels are just a shade over 13" wide and not having a wide belt or drum sander, I proceeded to plane them by hand to flat and level. That's 12 sides!!! I almost worked up a sweat!
Some pics
The 1/2" spacers needed to use the bow clamps
Applying downward pressure
Some pics
