Howdy All,
I am in the planning stages of my first real project and need some help so I don't learn all the lessons the hard way! :BangHead:
I am going to build a built-in bookcase to fit in a nook in my home office. Here is a rough sketch of the design I have so far. And just in case you are wondering (as my wife did), I am planning to put two doors on the lower cabinet. :gar-La;
I decided to do frame and panel for the both the lower cabinet and the upper portion of the bookcase. I plan to attach the different frames with pocket screws to build the carcass. The frames will be made from the Red Oak which came from our yard. I can easily get enough if I mill down to 3/4 thick. Is this sufficient, or should I shoot for 7/8 to 1 inch? To go this thick I may have to be selective on what boards I use.
For the panels I think I want Furniture Grade ply. I only need 1 side to be good as the other sides will be against a wall. Any suggestions on material and sources for the panels? If I want to finish it with BLO or just poly, will the ply look OK or does it need to be stained?
The only way I have to make the grooves in the frame is using my table saw, so I plan to make the grooves the entire length of the boards. In order to do this I would need to make the tenons and the plywood panels the same thickness. I am thinking 3/8 if the frames are 3/4. Is 3/8 ply readily available? Any other suggestions for how to make the grooves?
For the top portion of the bookcase I was planning on splitting the frames in half so I don't have to deal with making tenons on long boards (50+ inches). The tenons will also be done on the table saw with a jig, so 50 some inches + saw height gets pretty close to the ceiling. I think it will be sturdy since I plan to attach the whole thing to the wall as well. Based on your experience will this frame be strong enough to hold a lot of weight? Are there any major downsides to splitting the panel this way?
Thanks in advance for all your help. :icon_thum
Dave
Dave
