Any board extenders available?
Sharp Blade
Anna-Catherine
Self explanitory!
FredP
Fred
if size isnt critical you could recut the opposing side.:rotflm: but my board stretcher is all stretched out!
You can make the width of the frame members less from the inside edge. That is as close to a board stretcher as you can come.
Sharp Blade
Anna-Catherine
Al and others...are you trying to tell me I cannot stretch the board any? :rolf:
Well, I can use this board for another frame project coming up. Sheesh! What a dolt I can be.
Alan in Little Washington
Alan Schaffter
No board stretches left on the East Coast- I've used every one!!!!
How about a 3/4" piece of contrasting wood slipped between the miters? You would need to cut an inside miter on one end and outside miter on the outer end.
Sharp Blade
Anna-Catherine
I had actually thought of that. But, the guy I am making this for is too conservative to experiment with. LOL
mshel
Michael Shelley
If the width of the boards is not critical, you could make a long scarf joint and in effect stretch the board.
jeff...
I'm working on a board stretcher, but as close as I got was to chain a board between two tractors and pull. Really didn't work so well, but was fun, because we got to see which tractor was the strongest of the two.
Anna, try this, it is what I was trying to explain in my last post. If you can spare some width on the frame members, this concept will "stretch" your board. Scanned from American Woodworker -
(bottom article)
HTH,
FredP
Fred
yes you can! add more wood to the long side and rip some off the short side. remiter the ends and the board is longer but with a glue joint along its length. if you can match the grain it might not be noticed.
this also works.:hairroll:
Sharp Blade
Anna-Catherine
(bottom article)
HTH,
Dave,
I see what you mean. Since this is only red pak from fLowes, I got another board and will Make it right. I just wanted to show what a dolt I can be. LOL
I will keep this in mind for anything critical.
Anna-Catherine
DavidF
If the picture sits on a rebate (rabbet) then how about making the rebate wider so that the frame can be smaller and then recut the mitres?
Sharp Blade
Anna-Catherine
David, if my customer, my GF's brother weren't so dang particular aboput the frame, then tyours and almost everybody elses suggestions would be tried. LOL
I did get another piece of oak and have it all mitered and together. Just waiting to finish it off now.
