Very nice piece from design, construction, through finishing the finish. :icon_cheers
Never done dovetails, but I sure like the clean appearance of yours!
Could you and Joe give us a little tutorial about the layout and setting of the lower shelf? The fit looks excellent, but 2.5 hours is obviously not a quick slash and burn with the jigsaw. :help:
Jeff.
The real trick to setting the lower shelf; as I observed Joe, was accurate measurements between the inside of each leg, front to back and the length of the shelf. These measurements must take into account the same offset (in this case 3/8") that I used for the aprons to legs.
The other neat trick is to take all of the measurement's at the top of the legs/aprons. (ie should be the same whether you measure the top or the bottom assuming the legs/aprons remained square at glueup)
Once the outside dimensions were established we just crosscut the shelf to length and ripped to length, then marked for the leg notches at the point of each leg. It was then just a matter of "slashing" with the jigsaw (with the aid of Joe's sharp eye) and refining a bit with a rasp, file and sanding block. This was the time consuming part in getting the fit just right. Also a good dose of Joe's type of patience went a long way to a successful fit. We do have a tendency to work slow when we get together though!:wsmile:
Next time, I think that I will try to just let the shelf into a dado in each leg and glue.
Thanks for your feedback.
Wayne, you always do my wood proud!
I like how you did the dovetails too - did you cut those by hand or use a jig?
Your wood is always a pleasure to work with!!!
Dovetails.
Ya, of course they were all hand cut. Had to set up the Leigh jig for the correct spacing, set up the router with a dovetail bit at the correct depth and then a straight bit at the correct bit depth and route away. All sorta hand cut!:gar-La;:gar-La;:gar-La;:rotflm:
I'll know doubt be calling again soon for more great material for the next project(s).
