Well I've decided to take a stab at building a deck. I've decided to use traditional 'footers' (I think that is what they are called). The permit guy said that I needed holes 18" deep X 18" wide. I think I'll try to use those pier things so the wood posts are not in contact with the ground. Can someone detail exactly what I do from the point that the holes are dug for me. Most instructions I've read seem to skim over this part as if it is common sense and It probably is but... The deck will probably be ~20 X 12. I don't want to attach the deck to the house so I believe I'll need at least 6 holes right? At the highest point I expect the deck to be~ 4 ft. off the ground. Most places will be between 3-4 feet I believe. What size dimensioned lumber do I need for the girders and rafters? I thought the permit guy said 2 X 10. Seems a bit like overkill to me. That would be 19" above the posts before decking so 20.5" from the top of the posts to the top of the deck right? How far out of the ground do the piers stand? Alot of questions I know. Sorry...
