Ok first of all I acquired a dust collector today from CL, this one here as best I can match-up from HF;[FONT=arial, sans-serif] model number [/FONT][FONT=arial, sans-serif]97869-0VGA.
As I have read here before using 4" pvc seems to be no problem with this type as long as no 90 degree elbows are used sloping turns only. I have a small shop only 13 x 18 so space is tight. Yes the dust catcher is larger than the picture looked but that is ok too. I plan to run flexible from the collector "Y" run it up and over to near the band saw, router, a[/FONT][FONT=arial, sans-serif] miter saw, lathe and [/FONT][FONT=arial, sans-serif]bench top table saw (I know that needs to go). Would it be ok to run the down drop for all 5 and just switch the hose to which ever one I was using? I ask it this way because of space I have to put away some tools before I can use another.
I was looking at it after I got it home and noticed that the intake on the suction side was actually a 5" intake although it has a Y that reduces it to 2 4" connections. Would it bo ok to use the other 4" side as a vacuum cleaner for the floor with a smaller hose?
What size breaker does this need to run on? It tripped an outlet strip that I first plugged it into. Then In got unlazy and got a heavy drop cord like I shoulda done to start with.
I know, I know....no pictures it ain't there at all.....the batteries are dead in the camera..
[/FONT]
[/FONT]
