Way back in Sept '07, at the end of a thread about my tablesaw, I said that I was going to follow Monty's lead and my next project was to build a relatively traditional woodworking bench, also based on the design by Lon Schleining which was first published in FWW a few years ago (see the copy on my extension table). However there was always something with higher priority, and I never got around to it.
Then, last December, while working on my second adjustable height assembly (for a magazine article), I wondered if the adjustable legs I designed and built for those tables could be adapted to a woodworking bench such that the bench would be strong and stable and still be adjustable.
I broached the subject here and posted a few SketchUp drawings of the leg design. A few of you pointed out the location of the stretchers on the initial design would likely make it difficult or impossible to lift the top to adjust the table height.
I subsequently changed the location of the stretchers from the fixed legs to the adjustable legs.
Since I already had an indexing jig set up to cut the leg notches for the assembly table legs, I decided to make the woodworking bench legs at the same time using some beech I had sitting around the shop- that was nearly 7 months ago. This Spring I picked up a 30" x 72" x 2.75" maple top from Bally Block, then on a trip to Raleigh last month I picked up a few more pieces of beech at Klingspor, so finally, almost two years after having made the decision and 7 months after actually cutting the first pieces, I had all the materials (and made the time) to actually start working again the new bench. I didn't take any in-progress shots, but here are some pics of the nearly completed adjustable height trestle base with top installed. I still need to add maple aprons, 3 vises (QR front vise, sliding tail vise, Veritas twin screw tail vise), and bench dog holes.
Revised SketchUp drawing. (minus ratchet arms and release cords). Unlike my assembly table legs which stay together by sliding dovetails, these legs mate with a "V" and "V groove". The ratchet arms draw the leg halves tightly together and keep the matching "V" profiles solidly mated.
Side view of the new bench in its lowest position (top is 30-1/2" high)
End view showing top and bottom draw bored tenon pins on legs and wedged through tenons on stretchers.
Close-up shot of ratchet arms (minus release cable) and stretcher tenons.
Side view of bench at full height of 43-1/2"- the height can be adjusted in 1" increments.
End view at full height.
3/4 view at full height
The height adjustment mechanism works very, very, well (as good or better than the ones on the assembly tables). The bench is very sturdy, stable, and does not rack. While heavy, it lifts fairly easily -obviously one end at a time. I need to do some design work on the release cords because the legs are closer together than on my assembly table and there isn't enough side pull on the cords to release the ratchets properly. I have a few ideas, and it will come down to what looks and works the best.
