Well I purchased my first HDTV. :icon_cheers
It is the Samsung LCD TV and I am now working to get it set up.
It will be going above the vent-less, gas fireplace.
I already have worked out a good way to mount the TV over the hole.
What I have not been able to figure out is how to run the wires behind the fireplace down to the crawl space under the house.
This might be an easy job…..might also be a hard job.
I have no idea since I have never seen anybody run a cable behind a fireplace.
I am guessing that since a gas fireplace is fairly common, that there is some standard trick to getting wires run behind it.
I already have the power outlet in the niche. What I need to run is some fiber, an Ethernet cable, some coax and my HDMI cables.
I have searched everywhere I know and I can not get a good how-to on this.
I know it is possible because they ran some wires for me right before I moved in and after the house was built.
If it helps..this is a ranch style house.
The fireplace is on an outer-wall and that section of the wall sits farther out than the rest of the wall when you look at it from outside.
I have run a few wires in the past..but this one is throwing me.
BTW…., I have heard all about the viewing angle and the heat from the fireplace.
As an answer to this…
My house is 4 years old. My fireplace has never been lit.
Due to the fact that they do not run gas in my area and the tank seller in the area is insane, I do not know if it ever will be lit while I live there.
As for the viewing angle……due to windows and piano, this is the only possible place in the room to put this TV.
