I am building a side table with an "elevated" top (using stretchers under the table. The plan I have uses screws and glue to attach the top. In my case, the top is a single walnut board 15 1/2" wide by 36" long and 1" thick. I am afraid if I glue, movement could cause the piece to split over time and if I just use screws, the top may be separated if the table is lifted via the top. Also although it would be on the bottom, either the screws or plugs would show.
Would biscuit joints and only glue around the biscuit work?
Any thoughts on the best wat to attach are appreciated.
