Has anyone ever used a variable speed router control on a belt sander? I need to sand a butcher block down and am wanting to slow the sander down a little for better control. Will it work or will it fry the sander?
Bad answer, bad answer. Even though sander is rated for 115 volts AC, it most likely has a universal motor. Seldom do manufactures rate tools for DC operation. About the only source of 115 volt DC is some OLD engine driven welders, and I mean OLD. Most newer welders produce a combination of 115 / 230 AC, which allows them to be used as a generator. I have two PC 3 X 21 belt sanders, and one is variable speed. I usually grab which ever one is closest at hand. As long as sander doesn't have a "soft start" feature, you should be doing OK.Nope not unless you want to burn it up. Needs to be a universal motor.
So Bruce let me get this straight, it does need to be a universal motor or it would burn up. If assuming the sander is a universal motor the rheostat can be used?
