The stock size was 500mm x 500mm with a cutting envelope of roughly 300mm x 300mm. The stock machine is sitting inside the new 1M x 1M framework to compare the size.
I moved over all of the mechanical components today and the new cutting envelope should be right around 800mm x 800mm which will be a nice change. Just waiting on the longer belting and some various bits and pieces to wire it all up again with the longer rails.
I also moved the z-axis stepper back to give enough clearance to the spindle which also gave me a gear driven belt drive which should increase the speed of my z-axis.
The rabbit hole just keeps getting deeper
