Unused Woodmaster with pro-package FS
DECC
Dave
I purchased this Woodmaster kit new but just never got around to using it, I thought my job was going to go in this direction... at which point it turned quickly in another direction and I never got around to using this tool, I never really unboxed or assembled it, you can even see the original ties on the cords. I paid 11000 for it, my loss is your gain. This machine is a fantastic woodworking tool.
From the Woodmaster website:
Because it’s the Model 725, you get…
• Our BIGGEST machine
• Full 25” Cutting Capacity
• 7-1/2HP Cutterhead Motor
• Massive Cast-Iron Bearing Housings with 1-1/2″ Bearings
• 1/2HP feed motor with True Infinitely Variable Feed
• Feed Rate — 0 – 34’ per minute (from 70 to over 1,000 cuts-per-inch)
• 580 lbs. of vibration-dampening cast iron and steel (640 lbs. with Pro Pack)
• 2 Non-marking Industrial Rubber Feed Rollers
• Patented Quick-Change, 3-Knife, Morse-Taper Planer Head
• Two, Reinforced Steel Extension Tables
• Steel Stand
• Dust Chute with 4″ Port
• Super-Slick, 42-1/2″ Polypropylene Bedboard With Guide Rails
• Knife Set Gauge
• Complete Set-up and Operations Manual plus DVD
• Three 25-1/8″ High Speed Steel Planer Blades
• Made With Pride In The USA WHO CHOOSES the 725?
• Woodworkers who want the biggest & best
• Professional woodworkers
• High-production wood shops
Comes FULLY EQUIPPED for Planing
• Patented 3-Knife Morse-Taper Planer Head or optional Helical Cutterhead
• Reinforced Steel Extension Tables
• Heavy-Gauge Steel Dust Chute With 4″ Port
• Super-Slick Polypropylene Bedboard With Guide Rails
• Quick-Set Knife Set Gauge
These accessories let you set up your Woodmaster as a molding machine, drum sander or power feed, gang rip saw. We’ve “bundled” everything you need (plus important extras) into our Pro Pack. You save over 33%! PRO PACK INCLUDES:
• Accessory Shaft for Molding, Sanding, Sawing
• Molding Knife Holder For Knives Up To 3-1/4″
• Drum Sanding Kit with Belt, Pulley, Sandpaper
• 2 Rip Saw Kits with Carbide Tipped 5-1/2” Blades
If you have questions please feel free to ask, I am pretty firm on the price, $8200
