I just recently got some Cherry burl thanks to WoodArtz in the latest deal.
Now I am torn on how to turn them. I have turned burl before but it has always been in a nice square block form. These are not -
Most are half logs with the burl wood on the outside.
Normally when I turn a half log to make a natural edged bowl, I will use my wood-worm screw into the bark side. That will allow me to turn a recess or tenon in the middle of the log to chuck with. I reverse the blank and hollow out from the bark in. That gives a natural edge bowl, hopefully with some bark still attached.
In this case the figured burl wood is on the outside. If I used my natural edge bowl chucking method I am afraid that I will turn away most of the burled wood.
I would like to start the outside of the bowl as the bark side of the pieces so I can maintain the most burled figure in the bowl. My concerns are removing the bark on the lathe, the stability of chucking into the outermost layers of a burl, and how much I will have to removed to get the rough round. How have y'all approached this and what method have you used???????
TIA for your advice,
Dave
Dave
