Charlie Buchanan
Charlie
Saw a blog entry recently about making squares out of shop scraps and decided to give it a shot. The photos show the result. The grip is mahogany and the blade is beech--both quartersawn. The pins are walnut dowels. It has a couple of coats of shellac sealer then steel wool before finishing wax.
The blade is just over 1/8 in thick and the grip is a bit under 1/2--hey they were scraps after all.
pviser
paul
I love your work! Aside from being a beautiful and useful product of your handiwork, the lightweight wood is much less likely to damage your workpiece than, say, a perfect steel Starrett square.
Charlie,
How long did it take you to make it?
Is there a Square class / workshop idea there somewhere?
I have never done it, concerned that if I couldn't get it square, without help present - how would I fix it?
Charlie Buchanan
Charlie
Charlie,
Since I had the scrap stock already correct thickness it only took an hour to make the joint and the end shapes and sand it. A half hour to fit the joint and glue up. Probably 2 hours total over a couple of days as I waited for glue and finish to dry,
Don't know of any. But the the principle is the same as making any lap or bridle joint come out square: start with square stock and cut the shoulders square. You need a good square to make a square.
You square it as you dry-fit the joint. Make sure register faces of grip are parallel and the blade sits tight and square. When glue is dry check against a good reference square. Double check by the mark and flip method along a straight edge. If it is off square then plane the blade edge with a very fine-set shoulder plane to take off material just where needed. If it goes out of square in a few years it is easy to adjust--its wood.
merrill77
Master Scrap Maker
Hmm. Even _I_ don't need plans to build a try square.
I like yours, Charlie. The pics are more than sufficient :)
Rick M
Rick
John Heisz made some one piece try squares from plywood, want to 'try' that someday.
I made one from oak and plexi for the kids but like it so much I use it myself all the time.
Sent from my T-Mobile G2 using Tapatalk 2
