Many of the pieces are in the 40" x 6" long category, so any "diagonal" cut is minimal at best on my 12 1/2" TP.. The big problem is caused by grain reversals. Kind of the nature of the beast with QS (the lumber I bought was in the 9' to 12' range and, although sawn quite true, the grain just didn't seem to run exactly Starrett quality straight :confused_). I really don't want to use MS with the power planer (using a shop vac with side ducted chip extraction is not optimal to start with, and when I have planed green, i. e. wet, lumber in the past, it clogs badly; Not to mention MS is somewhat flammable). However, will go there if others have done so before. Right now, the static build-up is so great that when I open my chip collector (a dud shopvac in line with my suction vac) the chips actually jump out like popping corn.
I may try dampening the surface with water, but wanted to find out if anyone else had tried that and found the results worsened. All pieces are flat and square, but the thickness is at 7/8" now, so I can take it down another 1/8th if someone has an idea that shows promise.
Another thought: Can I expect the same from a router? These are the rails and stiles for a hope chest with floating panel design. If all else fails, I will bevel the edges with the TS (having done that in the past), instead of trying the router. I am planing on a series of trial runs on edges and ends before I commit, using the rail/stile bit set I just picked up form sears. It appeared to be better quality than the Skil set available at the Borg (Lowes).
Bottom line: I am pushing the limits of my skills with the tools I now have, so the end result may just end up reflecting that. Not to say the tools aren't capable of more:BangHead:!
Thanks for the reply
