some years ago I became the owner of a used, 3 hp Grizzly table saw.
I have not used it on a regular basis.
I can't actually call myself a wood worker, though I love to learn about it by reading and watching videos.
The table saw had been making a bit of a dragging noise for a while but I neglected to get to the bottom of it. The noise it made while running. While I was recently I was making a few small things to help in the shop... a holder for two cordless drills and some accessories, a charging station and a rest for my random orbit sander, the noise increased and them the blade locked up.
Next day, I took the table off and gave it a much needed cleaning.
If I very briefly bumped the switch on then off, it would try to turn but only go maybe a quarter of an inch.
Someone suggested spraying the shaft at the bearings with penetrating oil.
After I did that and waited a while, I flipped the switch and it turned again but with a noise that shouldn't be there.
So now I'm wondering if it might be bearings that will need replacing.
I managed to find a way to load a short video on FB but it will not allow the FB link here.
I'll try to find a way to load the video (with sound) but then again, you may not need it.
From the pics you can see rust. It has sit for a number of years in a shop that is not fully enclosed, no heat or air.
I have a tube of White Lighting lube to use after it is back in running shape.
