After a variety of issues, I was checking blade parallelism on my TS (Grizzly G0691 - cabinet saw) and found it was a bit off. I raised the blade to full height and re-aligned to the right miter slot using a dial indicator (~0.001" front to back). After lowering the blade to my cutting height, I re-measured and found that it was out of alignment again (~0.007" front to back). I raised the blade and checked again - dead on.
What's going on???:BangHead::dontknow::BangHead:
I measured at various blade heights to see how the alignment changed with blade height. I had a Freud Heavy Duty Rip blade and measured to the same spot on the blade. Measurement was also 1.25" above the table surface. (Sorry about the format - it's hard to make a table on this forum.:tinysmile_cry_t
I also verified that the blade was 90 degrees to the table, but even if it wasn't, it would not explain the alignment issues.
So, I don't know what to do next. Do I just re-align at somewhere a bit below full height and avoid cutting at full blade height (this is a rarity anyhow)? Or is there something that I'm missing?:dontknow:
I'd greatly appreciate any ideas.
Thanks in advance,
blade ht___measurement @ front___measurement @ back
3" (full ht)_zero indicator__________<0.001
2.75"_____+0.006________________+0.013
2.50"_____+0.006________________+0.011
2.25"_____+0.006________________+0.011
2.00"_____+0.006________________+0.010
1.75"_____+0.007________________+0.011
To verify that it wasn't due to blade warpage, I repeated the measurements with the same blade with the arbor nut loosened blade rotated ~90 degrees and arbor nut just snugged. I also put on a different blade (Freud Ultimate Plywood and Melamine). I got essentially the same results as above for all attempts. I replaced the original blade and re-measured and again got the same results (have lots of reproducibility).3" (full ht)_zero indicator__________<0.001
Thanks in advance,
