I used the same method with my first bench, unfortunately over time the track started coming out and/or getting bent if I used to much force to hold things down. I even drilled extra holes to try and keep it down.
If the track is pulling out. Don't use screws, use bolts with fender washers on the under side. My bolts are 3-6" apart depending on location/use of certain areas.
