Spindle Sander Refurb Complete!!!!
Alan in Little Washington
Alan Schaffter
A Spindle Sander is reborn. For those who missed my earlier posts, I picked up an old Max spindle sander on Ebay. I haven't been able to discern the date of manufacture yet but the serial number makes it 1980 or newer, so at the oldest it is nearly 30 years old. It was made in USA by Max. After going through various iterations, the company started in the early 1900's, is still doing business and is now partnered with Tannewitz a maker of big "old iron" bandsaws.
It looks like it had been used in a shop environment (it is a heavy duty industrial quality machine). When I got it the top was heavily rusted, the pedestal very dirty and greasy, the switch was missing, and one spindle was seized in the socket, but the insides, the gear mechanism, looked new and will likely outlast me! As to cost- a new one lists for $4400. with a street price of $3500!!!! I paid about one tenth of that plus $25 shop fee and less that $20 for sand paper, paint, gear oil and grease.
I tore it completely down; took the spindle socket to a machine shop have the seized spindle removed; cleaned, de-greased, and de-rusted everything; replaced the gear box oil and grease; painted the formerly green pedestal and trunnions with rattle can smoke gray; applied red paint highlighting to the stamped and raised cast iron markings, including the "Made in USA"; and installed a single phase motor and new switch assembly (shop spares). Not only does it look new again, it works great and purrs like a kitten!!
Rather than refer you back to previously posted pics, here are both before and after shots:
Complete unit:
Before:
After:
The top:
Before:
After:
Spindle and dust housing:
Before:
After:
Pedestal and spindle shelf detail:
Before:
After:
Another pic:
Carolina
Looks great Alan! I have the same Max sander. It's a very good machine. How many spindles came with your machine? Mine only came with three so I would like to find a few more.
Canuck
Beautiful restore there, Alan!:eusa_clap
Lot's of mileage left on that one!
A
Alan Schaffter
I think mine came with 9 of 10 although I seemed to have misplaced the 1/4" one. it also came with a 4" pneumatic drum and a 2" pneumatic drum spindle (w/o the bladder). You can get the spindles from Max but they aren't cheap! Do you have a manual? I can send you the pdf of what passes for a manual.
Mark Fogleman
Nice job Alan! Beautiful piece of equipment. I've heard of people fabricating spindles. Check with your machine shop. They can probably whip out what you need on their Bridgeport.
A
Alan Schaffter
My bother is just finishing up a restore of and a CNC conversion to a Bridgeport. I have a whole list of things for him to make for me- three more OSS inserts, an OSS spindle or two, one of those tablesaw throat plates that accept replaceable wooden zero clearance inserts.
cpowell
Chuck
I would love to have the space for a stationary sander so I could just walk over and touch up curves at will!! You did a great job on the restore.
It looks great. :eusa_danc
Chuck
T
toolferone
User not found
Looks great Alan! Just curious on how the motor transmits it's power to the unit. Doesn't look like there is room for belts.
A
Alan Schaffter
Everything is in line. The male keyed shaft at the bottom of the spindle mechanism mates with a female keyed shaft. The shafts slide and overlap enough to allow for the 1-1/2" vertical oscillations. The female keyed shaft exits the bottom of the oil-filled gear box through a bearing/oil seal then connects to the motor shaft via a Lovejoy coupler. It has a hard rubber spider to reduce vibration. All is very well made and runs very smoothly.
Alan, how did you clean the top??? What chemicals, abrasives, etc, did you use and about how long did it take?
It looks great!!! Very nice restore!
A
Alan Schaffter
I cleaned the top with a razor blade window scraper first, then used various abrasives from about 120 to 320 grit with WD-40 as a lubricant. It took a couple of hours because there was one fairly deep spot.
I wiped all painted parts with mineral spirits to remove the grease, using rags, and if necessary a brass toothbrush. Some of the aluminum casting was rough which knocked down easily with sandpaper. Then I wiped everything with acetone to remove any remaining grease or contaminants. I mounted the spindle dust shield in my lathe and used 320 grit to give it a polished machine look. Not visible in any of the pics, but I also removed the paint from the periphery of the trunnion lock knob and the table tilt hand wheel and polished the metal. It is not as nice as a chromed wheel but looks really good and much better than a totally painted hand wheel.
A
Alan Schaffter
Any kind of dust collection?
It came with a small shroud with 4" port which will be totally inadequate (the gray structure in the background of the pic below). I will likely make one that encloses the sides and the back under the table using a soft shroud or sliding solid sections, and has a 6" port.
By the way, according to the Mas website that small POS dust shield/port is a $200 accessory!!!
sawman101
Bruce Swanson
Really great restoration. That will be a fine machine in your shop for a longgg time.:thumbs_up
