I ran across and lost a hack for ultra-accurate setting of the stock thickness/depth of cut on the 735 planer. It has to do with either cranking down past the desired thickness and then backing off or setting the depth of cut shallower than desired and then cranking down to the working piece. The hack is a method for compensating for or eliminating the minute slack that is in the planer's chain drive on 4 screw pillars mechanism. Can someone either tell me what the hack is or direct me to a YouTube that shows how to set the depth to the tightest tolerances?
