scrub plane blade
Pop Golden
Pop
I am very sure I've destroyed a plane blade. What is the preferred radius of a scrub plane blade? The plane I'm working on may have too small mouth. What should it be on a scrub plane?
Pop :oops:
mdbuntyn
If you're talking about blades from a #4-#6, Mike's suggestion will work great. You can always change it if you find that it doesn't suit your needs.
"Real" scrub planes (Stanley #40, and similar) have blades that are around 1½" wide, and since their mouths are very large, they have a much narrower 3" radius.
The 8" radius Mike stated works well for me using a #5 Stanley style plane. I find that the #5 with the 8" radius blade gets most of the work I need it for, which is flattening a surface and eliminating twist and cupping.
I also have the Lee Valley scrub plane like Matt referenced. The Lee Valley has a much thicker iron to stand up to the stress of the smaller radius. I have found it best for really hard woods (set shallow), or for reducing the thickness of a board when it needs a lot of material taken off.
