If you are going to do custom reproductions of existing parts that need to be un-noticeable when they are set,
you have to do a careful illustration with the diameter sizes at each of the positions.
The further the legs are from each other when you assemble the chair or table the harder it is for the viewer to find the variations. So distance is good.
Not to be a show off like most of the guys I see on Youtube doing the same leg they have been turning for 20 years and making it look simple and easy if you go out and get a skew. You can see I have done lots of spindle turning. I don't like turning. I do it as a means to an end. I think the turnings are what makes the chairs I build look good or not so good.
This thread is about illustrations/patterns and story sticks. I think they are a must to get started as a turner and they are important if you are turning some new form. As soon as I turn out a leg, I mount it behind the blank I am turning with some homemade holding devices and I never use the stick again.
Looking at the 2 styles of legs below I know the largest diameter of the bamboo leg and the largest diameter of the baluster leg. Turn cylinders for each type of leg. Do 50 while your at it. You will be fast.
I usually don't turn curly but the customer is always right as they say. One Rhode Island style and one baluster style
The key is repetition. With all the legs I have turned, I still have to work into it if I haven't done any turning for a while. Kinda like playin' the guitar. Hopefully you still have some callus on you finger tips??
I still use these at the lathe
This is a time saver but truthfully I don't use it that much after I make my sample leg.
You can not turn these legs if you do not know how to sharpen your tools. Nuf said.
legs, stretchers, arm posts all need story sticks to get started. Sadly I don't have any these days.. I just take one down and use it to put my tick marks on the cylinder then its beads and coves.
middle leg above you can see a chip in the birds beak .. no problem that goes to the inside of the chair carriage and the viewer will not see it.
Here are 2 bamboos side by side. No.. they are not exactly the same. This is the closest the legs will ever be. The painted legs behind the 2 curly types are all different but hard to tell.
So.. do I think you need to start with a detailed stick? Yes.
