I am in the early stages of assembling my sharpening equipment beyond the Arkansas stones that I already have for my bench chisels. I have recently acquired two newish hand planes and intend to keep them properly sharpened.
I have done quite a bit online reading last night and feel that I am up to speed on the popular techniques but need some advice on implementation.
I like the idea of the hollow grind which should (with practice) allow me to do my final honing free hand. I do not have a bench grinder and so I am in the market for one. I do understand that heat is the enemy and ideally the wet sharpeners (like Tormek and its copies) should do the best to keep the heat down. So, is the wet sharpening type system designed to do the hollow grinding and put a final hone on the blade or is it just a more user friendly way to get the hollow grind without burning up the tip? Will a Tormek type system still need to have the tool finished on a fine stone or will it be finished on the leather wheel?
If both systems simply leave a hollow grind that needs to be cleaned up on stones or sandpaper it seems much more economical to buy a variable speed dry grinder and put the money saved into good wet stones.
Please help me understand the applications differences between a dry bench grinder and a wet sharpener for the purpose of sharpening and maintaining plane irons and chisels.
Thanks
Thanks
