Portable vise
pop-pop
Man with many vises
Five years ago, I led a Triangle Woodworkers Association workshop where members made seven (IIRC) portable vises. One participant cancelled thus I had a leftover set of hardware.
@bobby g has had one of these vises for several years and asked me if I could make him another. Since I had the parts (and he is a great guy), I agreed and made this portable vise for him.
The chrome plated guide shaft slides on two graphited bronze bushings. The screw pushes the chop via a spherical ball bearing which also serves as the garter. In the leg, a radial ball bearing and a brass square nut suspend the chop and keep the guide shaft from binding. Woods used were hard maple and air-dried walnut.
pop-pop
Man with many vises
Both end caps are secured with a screw with an O-ring as a cushion.View attachment 216884j
The tee for the tommy bar starts as a 1/2 x 3/4 x 3/4 IPT ordinary cast iron plumbing reducer tee. The smaller threads are drilled out 3/4”. The larger threads are drilled out 7/8” then 1”. The white plastic bushing is DWV PVC pipe with a longitudinal saw kerf or three until it can be pressed into the tee.
