I have surfaced several pieces of old oak. (John, I showed you a piece when I took your finishing class.) Most of it ended up being about 3.8" thick. With the new Rigid jointer set up properly and the plainer working right it looks pretty good. The surface is much better than you saw.
LOML wants 2 "under the counter" bookcases for her cook books (30" h, 24" w, 12" deep) with fixed shelves and on casters for accessibility. They will roll in sideways so only the sides are visible. I said that I would use the old oak and that I needed the jointer to surface it.
Now that I have run it, I think it is too thin to use without some sort of substrate. Is edge gluing it together then mounting the panel onto a 1/2" piece of ply a good idea? The ply will be visible from the inside of the book case so the surface will matter some.
I will rabbit the shelves in if I have enough thickness otherwise I will just use some cleats. I also remember your, John, suggestion of putting a runner under the front edge of the shelves.
I have red oak and white oak cut into 33" and 28" lengths. I have more if I need it so the supply is not a question.
For the finish, I plan to use oil and varnish. I may have to do some grain filling as some of the pieces are showing lots of small splits.
