I ask this because I know you guys are real good at helping others spend money. :lol: I want to take advantage of Woodcrafts 10% off Saturday if I can and I've budgeted about $350 for additional tools.
I planning on building an entertainment center based on plans in Woodsmith vol 29 # 169 to hold the new LCD tv and audio eguip. Heres a link to a bigger pic.
I'll be shortening the width a bit to fit the space and will end up looking something similar to this. It will not have doors on the end like in the link.
I'll be using cherry. The plans call for a ply case construction with face frames a solid panel top, and solid wood base frame attached to the cabinet. I,ll probably do 2 drawers at the bottem instead of one.
The top panel will measure about 48" by 20". I have 3 24" woodcraft parallel clamps and I know thats not nearly enough. How many more do I need to glue up a panel this size? I'm guessing at least 4 more.
Jointery for the base calls for pocket hole construction and because its suposedly fairly easy thats what I was thinking of staying with. Of course I've never done pocket holes and dont have any pocket hole jigs. I am considering the Kreg r3 kit. Prolly be good for face frames too.
The shelves will be adjustable so I'll need a drilling jig for shelf pins. Sugestions? The Veritas jig is way out of my price range.
Case joinery calls for dados. I've got that covered with the router and undersize plywood bits. I learned how not to muck those up last time I did this.
I've never done drawer construction so I'm not sure what I'ill need or run into there.
These are a bunch of questions but I know you folks are up to it. I probably haven't coverd everything so if you see any thing or altenatives I'm all ears
