I ordered a new paddle switch from Powertec for my Jet Contractor saw and it finally arrived today via USPS.
The switch description said "will fit in a standard box". Nothing wrong with the Jet switch, but I wanted to add the paddle to it for easy and safe shut off.
Took out the Jet switch and noted how the wires ran. Pretty simple. Removed the switch and installed wires on the new Powertec switch. Again, pretty simple. Took a whole 5 minutes to do. Got the switch back in the box and began to reinstall the two screws that hold it all together. Not so simple now. I had a terrible time trying to get the screws lined up with the holes. Finally got out the 12mm deep socket and removed the box from the saw to be able to see it better. That still did nothing to help. Finally took off the new switch and checked it against the Jet Switch and found out that the mounting holes are not the same spacing as the standard box would be. I went to the basement and pulled out an old box I had just to double check and sure enough the holes were not the same spacing from standard to the Jet!.
Why in the world would Jet use a standard dimension box but with different dimension mounting holes?
I had to reinstall the Jet switch back in the box and mount the box back on the saw until I can get out to Lowe's and buy a new standard box and do the install all over again. What ever happened to simple??????
