While shooting pics on the table saw for my mag article I developed a new appreciation for the Unifence. As most of you know the Unifence mounts in both a (standard) high fence position and also a low fence position, primarily designed for trimming laminate.
For the pics I set the fence low so as not to obstruct the camera shot. I actually made cuts during the photos (note spinning dado blade.) I really like not having the high fence in the way or my hand or push blocks, or either of them between the high fence and the blade. With the low fence, I can rip thinner boards without a special jig or push stick. Also, though I haven't done it yet, I plan to make a push block/sled that will ride on the low fence and guided by the small lip, for ripping even thinner boards.
While not suitable for all boards and situations, the fence in the low position has now become my new standard position. You need to be mindful of overlap (see second pic) if you are centering tenons or sliding dovetails and trying to remove equal amounts of waste from each side of dovetails. You can't make the centering cuts with each face against the fence, since after the first cut the rabbet and not the face of the stock the will ride on the fence.
