Re: need to drill a 2" hole 11" from edge
OK, I borrowed the drill, guide and bit from Saint (in my book) DaveD.
[STRIKE]If you catch this thread before I get back to it, you will see a bunch of photos below with no explanation. I am posting that way and will be back to edit in a bit[/STRIKE]...
First a little bit of
Thale's theorem to find the center (though the circle isn't perfect, so the center is not either, but it is close enough to true it to). If you look close, you will see pencil marks left by whoever originally made this; they aligned and marked, then glued up slightly off. I filled the center is filled with a slurry of sawdust and epoxy and let it cure for a few days. It had recesses on both sides that were a little under 1.5" in diameter and about 1/4" deep and it had a 1/2" hole that had been wallowed larger all the way through.
I used a small bit just for alignment of the guide. I decided to scew it down to ensure consistent placement; I would rather have a couple of small screw holes than another misaligned hole. The "C" penciled in on the wood is to note that the Crafteman label was on that side of the guide, so I would align it the same after I took the base off to check alignment (still to come).
I started with a 1/2" bit so that I would be able to check the alignment. Plan B would be to use the borrowed bit and go borrow time on the radial drill press from another gracious offer (y'all are awesome! :icon_thum) if the alignment wasn't good enough.
Done! Not all the way through, but close enough to test.
I stuck the 1/2 rod in and clamped it down. I gave it a few test spins and declared it adequate (will need minor truing).
About to screw the guide on again. I put the bit in the hole, lined up the label with the C and tighten the screws back into the existing holes.
Time to pull the trigger!
I would only do a little at a time, stop and vacuum chips and dust and let the bit and drill cool. Total elapsed time was about a day because I would just go drill a little more every now and then when I had the chance.
Finally through!
Even stopping often, I still had a lot of burning.
I dug through my pile of spindle blanks and found one with a section of 2" diameter to use to check alignment. Same process as with the 1/2" rod - spin it and see if it is workable.
I sighted down the groove at a spot on the floor and then spun the wheel slowly.
It needs minor truing, but it would not throw a belt as is. so I am pretty satisfied that I got this done and can move on to making the hub. I will continue to document the build in the thread I started about the treadle lathe:
http://www.ncwoodworker.net/forums/f32/wip-gloat-thanks-mike-davis-31487/
