Need Switch Cover For Delta 10"Drill Press
ndemarco
Nick
Both are good choices. I modified the design because I wasn't constrained by injection molding requirements. The screw hole bars span the entire back side. It's a much stronger part, even out of PLA.
I printed mine on a Phrozen Sonic Mini 4K.
kserdar
Here is mine - black PETG - 7 hour print. Printed on an Ender3.
Hot off the Printer.
Other side
Installed and tested - It did partially cover one of the ground screw holes. But I combined both ground wires on one screw.
Seems to be stronger than the original.
tvrgeek
Now, I would have gone ahead and gotten a nice big paddle switch and stuck it in the box.
kserdar
For only about $2 in plastic. I like the 3D printed solution.
Anyone else need one?
Over night, I made another one from Black PETG.
You cover the shipping and it is yours.
ndemarco
Nick
On the interfering ground screw hole, mine is the same. I took a WAG and removed 8 mm from model here. (magenta markup). I saw the same interference, and did the same as kserdar - piggybacked the ground lead. Notice they didn't remove paint on the casting front? Not-so-quality.
The quill casting front has draft, and I haven't figured out why my vee relief cut (yellow markup) doesn't extend through the whole part. I'm a Solidworks guy originally, so still learning OnShape. I'll update the model when I hear back from an OnShape forum post.
I also enlarged the switch screw holes from 3.2 mm (measured) to 3.5 mm (blue markup).
To export a STL file, read here. 3MF is not natively supported (shrug). I'll upload a STL after a few more tweaks.
deltaphisig
deltaphisig
Thanks to @ndemarco for putting up the file for 3D printing. Working on finding someone to print for me locally. Meanwhile, I repaired my original switch cover using Testor liquid model glue. It's really just MEK, but I couldnt find any at the hardware store. ABS pipe cement and acetone might also work. Can also make some DIY ABS slurry to reinforce your part. Links below for anyone seeing this thread:
JohnW
Grizzly has them in stock. Look up Woodstock D4163 toggle switch on their site. $6.95. McMaster-Carr also has many types of toggle and rocker switches.
For those with access to a 3D printer, the model is here, in OnShape (free 3D cad for personal use), and the STL files are here on Thingiverse.
Very nice work Nick! If anyone in the Cary area wants one let me know and i can print you one.
deltaphisig
deltaphisig
@ndemarco: Did you ever figure out how to get the vee relief cuts in the cross members? I am trying to teach myself all this stuff and stumbled my way through some other mods, but couldn't make that one happen.
Ralrick
Rick
Anyone know if that is the same switch cover to fit the Delta Model 17-965? Mine broke last year and I fixed it using some epoxy and wood pieces but would take (and pay) for the printed one if I can confirm it is the same part. I ordered the Grizzly part as it looked the same in the online drawings - it was worth a shot for $10 but it was too big.
Dee2
Gene
I may have one of those. Might be NOS. I'll have to fumble through some boxes.
