Now that the exterior on my 16x40 shop is almost complete (siding and roofing shingles this weekend) I need recommendations on what to use/do for the following:
- Insulation - walls and overhead (2x4 studs /OSB walls) R-factor, what kind etc
- Lighting - how many, what kind, manufacturer, location, wattage, etc
- Receptacles - both walls, ceiling. How far apart/how high etc.
- Paint - white paint on OSB both walls and ceiling to aid in lighting
- Ductwork - I plan on having separate interior roomfor DC and AC. Ducting can run in overhead if needed. Any good place or site to read on how to install etc. Dust will be directed outside into bin. No need to go through filter. Presently have 1.5 hp JET 1100 DC
Details of my shop are DUPONT6480 Workshop started.
Thanks again for your outstanding inputs and assistance!
Tim
Lighting: You need more than you think. I have ~600 sq.ft., and I have 18 T8 fixtures, each with two 4' bulbs (For my shop, using the shorter fixtures made more sense). There was an article in FWW a while ago about the necessary lumens per square foot. Of course, this is just ambient lighting, you'll probably want some task lighting as well. As for brand, there are many options. I went with the cheaper Lithonia fixtures from Home Depot. So far so good, no problems after 2 years. I'm sure the ballasts will go eventually, but I can then replace them with higher quality ones as I go.
Receptacles: I have a block of four receptacles (2 duplex) every 4 ft., 50" off the ground. Each block is on two circuits, so I can plug in a shopvac on the left and a router on the right and not worrying about overloading anything. Like Bill, I ran 12/2 with ground. For the 220V equipment, I ran dedicated circuits to each location. That's not required, but I had the space in the panel to do it.
Another option is to create a multiwire branch circuit. That's two hots, a neutral and a ground. This gives you the option at any given location to have a 220V outlet (using the two hots) or a 110V outlet (using one hot and the neutral). I did this in one spot in my shop, the closet where I house the compressor. I might upgrade it to a 220V model one day, and this gives me the flexibility. Perhaps superfluous, but make sure you put those on a double pole breaker.
Some people advocate running 10 gauge wire everywhere, in case you want to use some heavier duty equipment in the future (e.g. a 5 HP table saw). I think that's overkill. It costs more, and it's more difficult to pull (especially when using surface mounted conduit). Also, I find that stranded wire (commonly used for 10 gauge) is more difficult to make connections with than solid. The only location where I ran 10 gauge was for the closet where my dust collector is. The bigger cyclone units draw a lot of power, so you may want to plan for that.
Dust collection: This is a topic all by itself. Basically, go with the shortest run possible (going overhead vs. along the walls), no sharp turns, 6" pipe. Metal is lightweight, lots of fittings available at HVAC supply houses, and no static buildup that can zap you. But the edges are sharp and you may need to recrimp fittings. PVC is easy to handle, pipe is typically cheaper than metal, but it's a little heavier, the fittings cost more, and typically need to be mail ordered.
