Look I know this barely fits into the category of a woodworking question, but most woodworkers frequently need to think of creative solutions to mounting things, and so if anyone has any thought on this, I would appreciate it - if the moderator feels it doesn't belong, my apologies, please delete the post.
I want to mount a number of 2' x 4' panels to a sloped ceiling (this in a third floor room with sloped ceilings due to the attic). The panels are acoustic panels and have a 1 x 2 wood frame, and, here's the rub, are wrapped with an acoustic fabric, so you really can't do anything to the exterior of the panel without damaging the fabric. So you need to work from the inside of the panel - the inside of the panel has acoustic material (the fabric is used to cover the acoustic material) , but you dont need to worry about that - just assume you are trying to mount a 2' x 4' rectangle made by 1x2s, flush to a sloped ceiling, and need to work from the interior only. The edge that will touch the ceiling is also wrapped in fabric. I like the french cleat idea along the top edge of the panel, but then can't figure out how to affix the bottom edge to the ceiling. I've looked at varous clips, but nothing jumps out that is an elegant, relatively easy solution (we have to mount about 15 of these panels).
Any thoughts would be appreciated - thanks
