I see an awful lot of dewalts for sale on craigslist. Anyone want to chime in as to why?
It has all to do with training when they are puppies...If you want a bad Hitachi, I have one.
That's Hibachi, not Hitachi.It has all to do with training when they are puppies...
Only 3 what's up with that?Solely my opinion, but these tend to be workhorses, typically in the contractor trade and there have been numerous models for someone to upgrade to so that creates a secondary market (pawnshops, Craigslist etc.)
I have had three versions that I bought used and found one I really like.
This is a heads-up. I've heard rumors about the accuracy of the Bosch Glide saw. I thought this saw was the answer to prayer, but I may be wrong. Has anyone out there heard such? Has anybody had experience with this saw?
Pop
+1000000223457768 My de walt is close to 25 yrs old, ran thousands upon thousands of feet of trim on over a thousand houses and condos, still in my shop and running like new.
Pop
Pop
I recently looked into this saw, as I liked the ability to put it up close to a wall. One woodwork personality who I ran it by said that a school he was working at had one, and quickly retired it as it would not repeat accurate cuts. Frankly I was surprised. Then I got my hands on a new one that a contractor friend got. The 12" version. I make some cuts two weeks ago on 2x that he had at the job site I stopped by at. Indeed, there is significant (1/8"? did not measure it) slop, and this saw is out of the box two weeks before I played with it, and had not been dropped, etc. The unit is rugged, but it is not "tight." A disappointment for me. I still lug my 50# Delta cast iron miter around for projects, and can't find anything that has me wanting to switch...as much as I am ready to.
PM me if you want the snippets from the reference I mentioned.
Maybe they are having QA problems, but my saw is dead-repeatable. I use a zero clearance insert/base for it in order to make precise cuts, and after hundreds of cuts, the kerf in the insert is still the same width as the blade. I don't think I could even strong-arm it to be off by an entire blade width! (1/8") That is QUITE a lot of error!
K
I too own one of these. I have had it for about 6 months and use it almost daily. I was VERY impress the cut mitering 5/4 maple 8" across. The joint was tight and at a perfect 90 degree angle. And that was with the factory blade, I have since installed a Forrest blade on it. Kevin is spot on, sure you can deflect the blade by twisting it etc, but as he says, "dont do that"…I also have had zero repeatability problemsThis post may not be very helpful, as it doesn't quote any rumors, forum posts, online reviews, magazine articles, or 'this guy I know who knows this guy'. I only have one source of information.
I just own one.
I make picture frames on it and don't have to shoot the miters because the come off the saw (using a 100 tooth 12" Freud Diablo blade) accurate enough for assembly as-is.
Like any saw, if you pull hard on it laterally as you chop down, it will indeed deflect a little. So my advice is: Don't do that. The only thing that is bad about the saw is the dust collection, which doesn't. Which makes it just like any other SCMS except the Kapex.
if you want to try it, feel free to stop by my shop sometime.
K
