Howdy all,
I've recently moved to NC (Lake Lure) and am getting my shop in order. This'll be my first time making built in cabinets and a workbench like this, so advice is appreciated.
Here are a couple screenshots of what I've designed:
Attached is the sketchup file for more details.
A couple design criteria I chose, which I'm wondering if they're good/bad/worthwhile:
1. The drawers will run on 5/16 x 3/8 runners, with a 7/16 wide x 1/4 deep dados in each drawer. I designed this to allow 1/16 of slop on each side of the drawer.
2. The drawers have 1/16 spacing between the front frame and between each drawer, to allow for play.
3. The cabinets with 2 drawers will use 22" full extension slides. They're designed to hold 2x sys-2 tainers in the front of each shelf, and then a divider leaving misc space in the back.
4. The smaller drawers are sized as multiples of 1.5", so they can be rearranged in the future if need be. (Except for the bottom drawer, which needed to take up some extra space)
5. The height of the workbench is 38", the same as my laguna bandsaw. I hope to use it as an outfeed surface, which is why I added an extension table on hinges. The bandsaw and extension table need to move, however, if I'm to take out plywood from my rack.
6. The top surfaces will be 3/4" MDF.
The questions I have regard the construction. I've never built cabinets before, so I'm wondering:
1. Do I need a back? If so, how thick? 3/4, 1/2, 3/8?
2. Is the base I built adequate? Should there be other structural framing in the cabinet to keep it from sagging?
3. Do the 2-drawer cabinets need something more for the shelves on slides, or is it fine to just have them floating like that? Mind you I'm planning on installing 100lb slides.
4. The current drawers I have planned are: 6x 1 1/4", 10x 3 3/4", 2x 5 1/4", and 2x 7 3/4". Does this sound good, or should I go for more bigger ones?
5. Suggestions on door hinges?
6. Suggestions on what to do with vertical space on wall above workbench?
In terms of joinery, I plan on using Dominos wherever possible.
Thanks for your help, and sorry for the boatload of info. Any advice appreciated, and I hope my ideas can help out others in the future! Feel free to use the sketchup model to your liking. Included in there is also a plywood rack I designed, which uses less than one sheet of plywood (and a lot of screws ).
