I hate to post a negative review...as I usually think I must be using the product incorrectly. This time, however, I have no doubts.
I received a MLCS Marvel 40 3-in-1 router kit for Christmas. I needed to rout a large circular inset today, so I got out the Marvel. Before I go on, I have 3 other routers and 2 circle jigs - both of which I have used successfully (a home-made jig for a Craftsman router and the jig that comes with the Triton). So yes, I know how to make one of these work.
However, I cannot see a way to make this one work effectively. I attribute this to 3 serious flaws in this design:
1. The router base is flimsy. As you can see in the picture, the router is only supported by one piece of relatively light-weight stamped metal. This support can flex during use, allowing the router bit to move horizontally relative to the base.
2. Where the router base connects to the beam, there is significant play - allowing the effective radius to change depending on the direction you apply force as you go around the circle.
3. If you attempt to compensate for the above flaw by ensuring you apply constant outward force as you go around the circle, you will be pleased to find that the router base can rotate - which allows you to hold onto the handle all the away around. This, however, reveals the 3rd flaw - the base does not center the bit relative to the router, so as you turn the router in the base, it moves off-center.
I'm guessing it is hard to visualize the above. The picture below illustrates a little of it...as well as the results. It would take a video to illustrate the flaws fully, and this poor excuse for a circle jig just isn't worth the effort.
This router comes with several bases, and the others seem to work a lot better...they are certainly better built and sturdier. So I will reserve judgement on the rest of the kit until I get time to better evaluate it. If you are considering this kit and the circle-cutting feature is part of your reasoning, I cannot recommend this kit. If you buy this kit for other reasons, I recommend throwing the circle-jig parts in the trash...I did.
