Thanks. It’s not as complicated as it looks, just a series of patterns cut on 3mm ply. It is app 11.5”. The outer layers are most complex so take longest to cut. There are 7 layers I think. Every other layer is stained.Wow, wonderful.
Can you tell me more? What materials are used here? What size is this piece?
Lasermaster 10W.That's very interesting. Nice job.
What laser cutter are you using?
Thanks it was easy enough thoughSince these are laser cut, you have better options for alignment.
"Glue up is a little tedious. I made a jig with 3 points I’d contact to keep them aligned."
Have the laser cut round (1/8", 3/16", 1/4". etc) holes at a spot that is solid in all layers. Fill the holes with dowels, fluted dowel pins, etc..
Tell the laser to "ignore" the top layer holes.
While you are at it, have the laser score the layer number for each level (again ignore for top layer).
The more complicated layers maybe 45 minutes. If I had to guess the whole thing took maybe 3 hours.That must have taken forever with a 10W laser ... How long did it take?
