Purchased a modular tool rest for my Laguna 15|24 lathe. Was disappointed to find that the post didn't tighten up easily. The new post is (1in x 5in) is 0.016 in smaller in diameter than the original (0.9775 vs 0.9935). I was able to tighten it up with a little extra effort on the crank and it held well, however, this made it difficult to reinstall the original rest. I was able to pry the opening back into position so the original rest works OK and as workaround I just put a turn or two of painters tape around the new post so it tightens up w/o having to do excessive tightening.
While I can find some fault in the new rest, I'm disappointed in how Laguna designed the banjo since it's in effect trying to squeeze together the cast iron material and after it's compressed, it doesn't spring back. Anyone else have similar experiences trying to get 3rd party rests working with the Laguna Banjos? I'm trying to understand if this low-cost modular rest was substandard, or is the laguna design just poor and likely to have problems with other rests as well.
I'm also debating if I can live with this 'tape' workaround or if I should return it and look for better fitting rest - I suspect the tape will occasionally be a hassle and need to be replaced, but I don't see any obvious reasons it would be unsafe or have any potential to do damage to my banjo.
