Last time I did this (thinking) I got a splinter, that drew blood... :gar-La;
But lets just think for a moment. Lets say a guy wanted a close to perfect as posibble loose tendon joint. lets say for example it's for attaching a arm to a chair or could be any other place where you want you use a loose fastening method.
Do they make double sided sand paper that's flexible enough where a guy could put a piece in between the two pieces of wood to be joined, apply a little pressure to the joint and pull the sand paper out. I'm thinking that repeating this a few times would create a near perfect matched joint irregardless of the profile. Then install the loose tendon, dowels, screws, biscuits, ... glue and clamp away.
Am I all wet on this one, would it work?
