I have a small shop (single car garage) and for the past couple of years have heated it with a 8,000 btu Mr. Heater Buddy series heater attached to a 20lb propane cylinder. Obviously this heater is way under sized for the space and does not keep the area very warm in the middle of the winter. I was given a 20,000 btu Comfort Glo ventless propane heater and am trying to figure out how to plumb it. I don't have enough free wall space to be able to install it in a wall and it comes with attachable feet, so ideally I can put it free standing in the front/middle of my shop.
I already have a 5' hose that connects my Mr. Buddy heater to a 20lb cylinder so one end threads into the cylinder and then the other end has a 1-20 outside thread fitting to go into the heater. http://www.mrheater.com/5ft-propane-hose-assembly-1281.html as far as the connection to the Comfort Glo heater it has a 3/8" inside thread input into its regulator, so I was going to use this kit from Northern Tool which also gives me a shut off valve https://www.northerntool.com/shop/tools/product_38915_38915
My question is does anyone know of a fitting or a couple of fittings to connect the 1-20 hose fitting to the 1/2" FPT fitting on the other side of the shut off valve? Links and any answers are appreciated.
