This is the first of a few threads that I am planning that detail my fabrication of this table initially described in this thread (started earlier today)
http://www.ncwoodworker.net/forums/showthread.php?p=353122#poststop
Here is the finished product in it's final destination:
I purchased S4S stock from the Heartwood Pine Floors Inc in Pittsboro, and it was quite usable straight from them. It is a good thing too because at 10'+ most of these pieces would have really 'stretched' my capabilities to process. For TS rips I can open doors to process longer materials, but I don't have jointer and I would have to take my planar outside to process anything longer than about 6.5'.
I simply culled the material that would not make it - either not perfectly straight or had a defect that would not work well for table top. I ordered 18 pieces (expecting to make other projects as well), needing 8 pieces for the top.
One of the eight pieces had about an 1/8" bend at about the 8' mark. I dry fit this and found that could close it reasonably well with clamps, so I just went for it.
I laid out my best combination, and then mixed them up again as my wife and I considered other possibilities. That was cool - the first time she has helped me grain and color match! Here is the end result.
With 8 pieces I had to glue up in parts, 3, 2, and 3 pieces each:
1.
2.
3.
For these 2 and 3 piece glue ups I used all the pipe, F-stype, and Al track clamps that I own. I also used most of a 16 oz bottle of Titebond 3 in the first two glueups. I went to my local (Raleigh) Woodcraft and wouldn't you know it, they had a sale and there's no more 16 oz bottles TB3 in stock! It was a choice of a gallon or many 8 oz bottles. Since I was using the better part of 8 oz of glue on one glueup, I just decided to go for the gallon size. Does anybody need 16 oz of TB3? I clearly did not starve any of these joint from their just amount of glue - but I was sorry that I was not more judicious in cleaning off the excess while it was still wet.
Then came the crux of it - gluing three individual glue ups into one big one. For the 40" reach and a 10' long piece, I needed about 10 clamps.
Well the shame of it, I only had 2! NCWW to the rescue:
http://www.ncwoodworker.net/forums/showthread.php?t=35796
Chris has graciously loaned me 6 (or more?) clamps that could span the need size. It was great to meet him and get a shop tour while I was at it. Many thanks Chris.
Here's the final glue up:
I did not use biscuits or dowels in the glue up, just TB3 and clamps. Before progressing with flattening or sanding the top, I had to scrape a lot of glue off; I should have scraped that off when the glue was still soft - lesson learned. I usually do not have as much excess glue - but rarely have I had to go for a walk along the length of a glue up to cover the entire edge with glue. I guess I chose to err on the side of too much rather than too little glue. I used a paint scraper and found that filing the edge to create a burr made a huge difference. I did not prep this entirely like a card scraper, but just filing the edge helped tremendously.
In the earlier general post on this table someone commented that flattening a glue up that size must have been fun. Well I tried my best to align the surface during glue-up to avoid doing much flattening. The ends of a few boards were not so cooperative, but for the most part any ridges were 1/16th or less. I also admit that the entire finished table top was not a perfect plane; there were some gradual undulations.
I used my 6" RO sander with 60 grit paper to level as recommended by the folds at the Heartwood Pine Floors place (wood supplier). They had apparently just finished a 15' long conference room table and used a floor sander to level that. I considered renting one, but when I tried my Ridgid ROS, I figured I could do it facter and cheaper than renting a floor sander (not faster unless you account for the time to pick up and drop off the rental machine). Norton 3x paper was available in HD when I needed it - thankfully I generally do not need 60 grit paper for my projects, but I did here. I also love that Ridgid ROS! A ShopVac on there keeps it fairly dust-free. I chose to do the roughest 60 grit stuff outside on the picnic table (we may not remember, but we have had a few warm days in January) and then finish sanding in the shop.
Here's the table top (now inside the shop) sanded to 100 grit, before staining.
I only sanded to 100 grit because this piece was not going to be a high gloss, super smooth, grain filled table top. In fact the request was the "more holes and knots the better - as long as the holes don't go through to the floor." With that kind of a surface, I did not see the point in fine grit sanding. There are residual nail holes, knot holes, and simply grain voids in the surface - and I like it that way. It did however challenge my notion of a "properly sanded and prepped surface."
Here is the top after stain:
At this point I moved it out of the shop (so I could move on to making the base) and into the basement where I applied polyurethane - several coats of oil based wiping varnish in a satin gloss. Once again a high gloss finish was not the aim here - the opposite in fact. I wanted the protection needed for a kitchen table, without a lot of shine.
At least one more, if not two, threads to follow - dealing he fabrication process, challenges, and complications in making the base.
Henry W
1.
2.
3.
Henry W
